ran into a rather odd PCV issue.. take a look
i purchased some center bolt valve covers off a member here about 5 months ago.
Anyways, i just noticed that on the passenger side, I only have 1 90* tube coming out of the valve cover.. its the one facing the front of the car. I looked to see if the 2nd one was welded upon removal and its not, its like this from the factory.
So, the issue i have is the rear PCV lines. What should I do? just run a PCV from the rear driver all the way around to the bottom of the front of the intake.. and then keep the front passenger side to the TB? and cap the part of the Y junction?
I also bought a grommet and a PCV valve for the rear driver valve cover.. so i was thinking about just runing a 3/8 hose from that to the front bottom intake.
any other idea's? (no dont say breather..)
I did the same thing. The valve covers I believe are from a truck.
I just capped off the breather line that went to the old port that is not there anymore, as it is all connected to the same place anyhow.
