pacesetter LT's question
Old 06-23-2007, 09:38 PM
01redws6ta's Avatar
Default pacesetter LT's question
Well, I just got my new set of these and they came with copper gaskets, bolts, etc. Are the supplied copper gaskets better than the steel GM ones or should I just go with those? And, which bolts...stock or supplied ones? Thanks for any input!
Old 06-23-2007, 09:50 PM
Black02Bird's Avatar
i reused with no problems at all
Old 06-24-2007, 10:59 AM
c0ncEpT's Avatar
I also reused stock gaskets with no leaks at all
Old 06-24-2007, 11:05 AM
99NMB's Avatar
I reused the stock ones also.. no problems yet... make sure you retorque the header bolts after 300-500 miles...
Old 06-24-2007, 11:09 AM
0utlawTorn's Avatar
The copper gaskets are junk. Reuse the OEM ones or just buy some new GM gaskets, $19.99....that's what I did. I reused the stock bolts, no problems either.
Old 06-24-2007, 04:50 PM
01redws6ta's Avatar
Thanks for the feedback guys. I will use my new GM gaskets and reuse the stock bolts then.
Old 06-24-2007, 04:53 PM
drummydummy's Avatar
+1 on reusing the old gaskets and studs. No leaks and no problems. enjoy the headers and do yourself a favor...run around your neighborhood at least once or twice with open headers. you won't regret it
Old 06-24-2007, 08:15 PM
wilwhite2kss's Avatar
i BOUGHT A NEW SET OF GM ONES, BUT I THINK THEY ARE REUSABLE.
Old 06-25-2007, 12:11 AM
Juiced2000SS's Avatar
Same here!
