LS6 Valley cover vs. Catch Can
I have both an LS6 vally cover and a catch can (currently uninstalled). I've searched around and can't find a clear answer on weather I sould run one over the other or should just do both. I have an 02 TA and I'm unsure if I'll need to cut the block for the LS6 valley cover to fit? Is there a benifit to running one over the other? I'm getting a little bit of oil in the intake so I'm hoping to fix that with installing either. So what should I install and why? Thanks, ken
Originally Posted by MeentSS02
Bullshit
And I still have the chunk out of my block (2002) to prove it
It really isn't that big of a deal though...as for what to do, I run both, and it works just fine.
I have an 01 and had to cut my block. Not all 01-02s got the LS6 block. Anyways, I run an LS6 valley and a catch can. The LS6 valley was worthless. I got just as much oil in the intake as before. The valley does make a nice shorter route to the can tho. I'd say if you have to cut the block then skip it, if not, then use it. If it works and keeps your intake dry, great. I'd hold on to the catch can tho, you may need it.
Kleeborp the Moderator™
Originally Posted by sroach20
damn, you got screwed. i put one on an 01 and 02, no machining required.
