my ls6 intake install w/ pics and questions.(holy dirty valley)
Old 08-02-2007, 06:36 PM
u lose's Avatar
Default my ls6 intake install w/ pics and questions.(holy dirty valley)
well i pulled the old intake off... not to bad at all thanks to ls1howto.com my ls6 intake didn't have the port seals so i am reusing the one from my ls1 intake. anyone see a problem with this? they are in great shape and fit perfect. they have the same part # as the ls6 ones.
i'm keeping the coolant line where they are. i knocked out the ribs on the bottom so it would be a good fit. i think i'll have to lightly flatten the coolant lines themselves. this is what others have done with good results.
i got this intake for $150. the red doesn't bother me, actually its a good paint job and my car is black. i think i'll get some black corvette fuel rail covers too.
i vaccumed out the ports but didn't clear them off with any cleaner.. should i?? no loose debris left but its just dirty...
also when putting the intake back on, do i have to put those 2 spongy pads that were on the underside back on? thanks!
Old 08-02-2007, 06:45 PM
5_02ls1's Avatar
as long as the seals are soft use them...and you dont have to use the foam....i used a shop vac and parts cleaner to clean up the valley on mine....
Old 08-02-2007, 06:48 PM
u lose's Avatar
how did the pic of my cam get in there???? ha.. any reason i couldn't use caliper cleaner a rag to clean them up?
Old 08-02-2007, 06:49 PM
u lose's Avatar
and the seals are very soft.
5_02ls1's Avatar
any cleaner should be fine....
Old 08-02-2007, 06:50 PM
5_02ls1's Avatar
sounds like the seals will be ok....
Old 08-02-2007, 08:14 PM
01Z28M6's Avatar
Can I show you mine? Thanks for sharing.
Mine's dirtier than yours no?
Old 08-03-2007, 04:42 AM
bsf
bsf's Avatar
There have been concerns that the foam pads actually contribute to knock sensor corrosion and failure. I am not using any.
Old 08-03-2007, 05:03 AM
andrew69_04's Avatar
wow your motor looks like crap inside. is that sludge buildup? i pulled a valve cover on my 60K ls1 and it looked almost brand new still. let me guess....pennzoil
Old 08-03-2007, 06:17 AM
King Nothing's Avatar
Originally Posted by u lose
hmm nice lookin intake . . . kinda looks familiar
Old 08-03-2007, 06:18 AM
u lose's Avatar
no its wet leaves and dirt... the car has only been driven like 2k miles in 4 years...
