pacesetter header bolts
Old 08-30-2007, 02:45 PM
scott5586's Avatar
Default pacesetter header bolts
i just got my pacesetter lt and ory package from tsp. i was just wondering if the header bolts that came with it were fine to use or should i order some of the stage 8 bolts????
Old 08-30-2007, 03:09 PM
camaroguy26's Avatar
I used the ones I got with my pacesetter mid-lengths and didn't seen to have a problem. But they rusted quickly just like the headers. I just pulled them off last night swapping in some longtubes and I noticed the gasket was black showing I had a leak. Not knowing if it was from the bolts or undertorquing but I'm guessing undertorquing since a couple of them seemed too easy to remove. If you use them just double check the torque after a couple hundred miles of driving. But Grade 8 bolts are always nice
Old 08-30-2007, 03:15 PM
tylerdj's Avatar
You can reuse your stock bolts if they look good.
Old 08-30-2007, 03:32 PM
Fifedogg's Avatar
I also used the bolts that came with my Pacesetters. I have yet to have a problem, but ive only had them on for maybe 4 months. I would just check them periodically and make sure they stay tight.
Old 08-30-2007, 05:01 PM
5_02ls1's Avatar
i used the ones that came with mine with my stock gaskets never had an issue ...been on since early febuary....
Old 08-30-2007, 08:07 PM
sixvi6-camaro's Avatar
I reused my stock one son my Kooks 1 7/8's. If I change to anything it will be studs. I've used the stage 8 bolts in the past and found them to be a pain more than anything else.
Old 08-30-2007, 08:16 PM
FadedSS's Avatar
i used my pacesetter header bolts with brand new oem gaskets...
Old 08-30-2007, 08:35 PM
CAMAROZ28AQUINO's Avatar
i just reused the stockers
Old 08-30-2007, 10:08 PM
scott5586's Avatar
ok thanks guys, i guess im just wait and see how the stock ones look after i take them off but if not then im just goin to use the ones that came with it.
Quick Reply: pacesetter header bolts
