PP 85mm TB users... come on in.
I just installed one of these throttle bodies that I bought new from a member here on the board. My question is that the throttle stop is preset from PP with a dab of yellow thread locker. After I installed this I threw a P0507 code for the idle being too high. Does anyone know if these are preset to a certain tolerance from PP? I am guessing that I need to back the screw down just a bit but wanted to make sure before I messed with the settings. I am guessing that I can just measure my old throttle body and use the same measurement to set up the PP 85mm. Will these correlate at all or am I comparing apples to oranges?
Josh
Josh
Moderator
I'd check for a vacuum leak first, the IAC ought to
be controlling idle and not the TB mechanicals. But
if there is too much air coming through other ways
then the IAC runs out of authority.
I am going to log my IAC counts before I touch anything tonight. My wife was rushing me to eat dinner so I wasn't able to fully diagnose the problem yesterday.
