How much power can I get form ported/polished LS1 heads?
I currently have an LSX 90/90, 1 7/8 headers, and a 234/235 .590/.610 (i think) cam. Right now the car puts about 405 to the wheels, on a bad tune.
My brother told me about a guy on here that will port/polish LS1 heads to match whatever setup you have.
So... how much HP can I expect to get from a set for worked heads?
its possible..i know a guy that put down 460 on a stang dyno with ported ls1 heads. The ports of a 5.3 head and a ls1 head are the same, the only advantage the 5.3's have are a smaller combustion chamber which will raise your compression ratio but other then that there isn't much of a difference in the flow numbers
