Header Install
Old 11-25-2007, 08:21 PM
99_SS_LS1's Avatar
Default Header Install
Well I've about completed my header install. Went really good for the most part. Having difficulties with the y-pipe (AHR) fitting into the catback (gmmg). It seems as the catback pipe has a lip around the inside of the pipe that probably should be grinded off, to allow clearance..?
I started it up for idle and a few revs with just headers and y (with cats) on. Sounds mean as hell.
A couple questions.
1. Quite a bit of smoke coming out of the engine bay. Don't think there are any exhaust leaks, probably some oil coating burning off the headers?
2. I deleted EGR and AIR. No CEL, but a SES light. Does that seem right?
Questions, comments, concerns are appreciated
Old 11-25-2007, 08:25 PM
Boosted 99 TA's Avatar
your light will be on since you took the emission stuff off.the smoke is probably just from handling the headers with greasy hands.
Old 11-25-2007, 08:33 PM
monsterbreather's Avatar
A couple questions.
prob something you disconnected and didnt go back on right. my bet an 02 sensor damaged or disconnected. smokes everytime with a header install for a bit.
Old 11-25-2007, 10:51 PM
1997compT/A's Avatar
If your headers are coated then some of that burns off when you heat it up for the first time. You should just throw a SES light once it figures out everything isn't there (rear o2's and emission parts) Took mine a little bit to kick on.
