hanging mufflers for true duals?
Old 12-15-2007, 12:27 AM
cals400ex's Avatar
Default hanging mufflers for true duals?
is the only way to hang a muffler for a true dual setup with a hanger that needes welded on? i really dont' want to weld a hanger on. i would prefer to clamp something on so it can be modified a bit if needed. i plan on running an X-pipe and with dumps. i am not sure on the muffler but the dumps will be about as far back as the rear axle.
Old 12-15-2007, 05:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You can drill through the bottom of the rear seats into the tunnel and bolt a bracket there. No welding. However, attatching it to the turndown/muffler will be a task. You really should weld it or make a flange that has a piece of steel rod with a hook on it to slip through. Clamps (if they worked right) would still suck and be my last option. Why can't you weld it? Or have it welded?
Old 12-15-2007, 01:51 PM
cals400ex's Avatar
i could have it welded. i would just rather not. i just change my exhaust enough that i don't know how long i will like the setup that i go with. with it not being welded then i don't have to mess with the mounts when i do change setups again.
