battery terminal connection issues....
Old Dec 14, 2007 | 02:32 PM
ls1 kids bro's Avatar
From: Was Long Island NY - Now Fort Lauderdale Florida
Default battery terminal connection issues....
I spent a lil time searching through past posts here but didnt find anything on the subject
my 2000 Z-28 wont start, i checked the terminals, they're clean, and even cleaned them some more, sandpaper and scotch pad, the battery is reading 12.65 volts at the terminals
inside the car, i flip the key over and its just reaching 10 volts, try and start it and she turns over, but way too slow to start
so has anyone had trouble with the wiring harness leads tying to the battery? I'm curious to see if i need to clean any other connections or if i need to cut off the rubber boots that hold the screw things to the battery
Any help appreciated!
thanks in advance
Old Dec 14, 2007 | 04:43 PM
2001NBMZ28's Avatar
I'd bring the battery to somewhere like auto zone, they'll do a load test on it for free. One of mine acted similar and battery was going bad, even though it showed 12.7 for a few days I could tell something was wrong. Didn't have enough amps to turn the car over.
Old Dec 14, 2007 | 05:58 PM
thanks, I'm going to swing by the local place tommorow
Old Dec 14, 2007 | 06:01 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Battery Problem.
Old Dec 15, 2007 | 03:25 PM
load test turned up a bad battery, bought a new one and the car is not cranking, the solenoid isn't engaging, so ill have to check that out in tomorrow in the garage where im not freezing my *** off
