NEW Flowmaster Super 44 Single In/Dual Out Muffler
Old Dec 12, 2007 | 12:11 AM
ChocoTaco369's Avatar
Tech Resident
Default NEW Flowmaster Super 44 Single In/Dual Out Muffler
This is something I just found that's very interesting. Flowmaster's new Super 44 mufflers also come in single 3" in/dual 2.5" out. I've never heard of anyone trying to use these for a catback. Why not?
The case dimensions are 4" x 9.75" x 13."
I can't see it flowing that badly. There's nothing much to it and it's labeled as their best flowing 2-chamber muffler ever.
Looks like the flow path is pretty good, especially in comparison to the 80 series:
YEESH, it's like a labyrinth in there.
Now, according to Flowmaster's installation instructions, the 80 series muffler in the catback for the 1998-2002 F-body is #530831. On Flowmaster's website, the muffler listed as 53083 has case dimensions of 5"X10"X17". This makes this muffler SIGNIFICANTLY SMALLER (and lighter) than the 80 series, so it'll definitely fit.
So, let's understand something: the muffler is smaller, lighter, it flows better and produces the coveted Flowmaster sound...in fact, it may produce an even BETTER sound since it's a muffler more geared for true dual applications and for Mustang's. It should be louder, too....so why doesn't anyone try this?
If there's anyone out there that wants to try this muffler, feel free. I'd love to see it for sure. It also comes with an off center inlet, too.
That may or may not be better suited for F-body applications.
Here's a page with all the part numbers:
http://www.flowmastermufflers.com/44_super.html
Old Dec 12, 2007 | 12:51 AM
Grimes's Avatar
does the side with two openings have an inlet and and outlet so it can be used in a catback like ours?
Old Dec 12, 2007 | 01:08 AM
Tech Resident
I'm not sure. Judging from the pictures of the 80 series, this muffler is laid out the same. It's hard to tell looking at the pictures, but it looks to me like it would work. It looks like it's too short to fit in the stock muffler location, but a few inches of pipe would fix that right up.
Even if the inlet/outlet locations don't work well, you could always have tailpipes bent at a muffler shop. You see all these people making custom true dual setups to get that Flowmaster sound. Why not make a custom y-pipe setup using this muffler? It'll probably sound better than any catback on the market right now, plus be a lot cheaper and have better ground clearance in general. This muffler doesn't look to be nearly the flow restriction the 80 series muffler is, so it should perform well, too.
Old Dec 12, 2007 | 04:14 AM
DarkJuggalo's Avatar
interesting, i would love to hear this in action ;D
Old Dec 12, 2007 | 08:46 AM
RevGTO's Avatar
Pontiacerator
It looks like the outlets are both on the same side, and in that case, it won't work for us. Same with the Hooker Max Flow.
Old Dec 12, 2007 | 08:55 AM
Grifter's Avatar
I never really liked the sound of Flowmasters on late model cars and there's an *** load of baffles in there.
Old Dec 12, 2007 | 09:02 AM
jmm98LS1's Avatar
Sure it will. Some f-body catbacks use a muffler with outlets on the same side, then loop the tailpipe back around the muffler to exit on the passenger side. Doesn't magnaflow do it that way? I know I've seen some that do it like that.
Old Dec 12, 2007 | 09:42 AM
WhosNXT's Avatar
Listen to Jmm98ls1 car and tell it doesnt sound good
Old Dec 12, 2007 | 11:30 AM
ls1_doc's Avatar
No it will not work. The 80 series has an inlet and outlet on the same side. That forty series in both outlets on the same side with the single inlet. I can take a picture of an 80 series if you dont get what i am saying.
Old Dec 12, 2007 | 11:32 AM
RareBreed0295's Avatar
I know i got the flowmasters 40 series on my car right now and it sounds like ***. Wont for long though..duals and headers go on this weekend.
Old Dec 12, 2007 | 11:49 AM
Tech Resident
Guys, it'll work. Just have a tailpipe bent. With all the work people go into fabbing up true duals, all they have to do to use this is fab up a single tailpipe to make use of the other outlet.
Old Dec 12, 2007 | 01:26 PM
jmm98LS1's Avatar
Here, take a look at my 1st grade quality drawing (shut up).....this is how you run a muffler like this on an fbody. I know for a fact at least one aftermarket manufacturer makes their f-body catbacks this way (can't remember who), but I've seen a few of them. There's plenty of room and it's super easy to do.
I've got super 44's on my C10 and they sound killer. I think one would sound real good on an f-body with headers.
File Type: bmp
Old Dec 12, 2007 | 03:36 PM
LTLRDSS's Avatar
jmm98ls1 i love the drawing, im gona get a super 44 for my blazer and later on maybe change out my single chambers for the 44's
Old Dec 12, 2007 | 03:55 PM
phoenix305's Avatar
more bends= less flow
Old Dec 12, 2007 | 04:14 PM
andrew69_04's Avatar
i have seen that catback your talkin about with the tailpipe that wraps around. this muffler will work, and i really dont think it would be very hard at all. Honestly i loke the flowmaster sound, but the 80 series sucks *** period. i think the super 44 would sound pretty good on there. i cant believe no one has put one on yet.
Old Dec 12, 2007 | 05:05 PM
Tech Resident
All catbacks will have the same amount of bends. The bend would just be in a different location. The "flow" will be exactly the same.
Old Dec 12, 2007 | 05:22 PM
CranMaro99's Avatar
Chambered mufflers FTL.
Old Dec 12, 2007 | 05:25 PM
INMY01TA's Avatar
Flowmaster sucks period. I had the 80 on my car, not only did it sound weak, two months after the Mac headers/ory went on muffler blew a hole in one of the welds. Knock yourselves out if you want.
Old Dec 12, 2007 | 06:30 PM
Tech Resident
Flowmaster probably sells more mufflers than any other company and no one else has problems. You got one bad one out of millions and Flowmaster sucks? How does that one work?
Old Dec 12, 2007 | 06:33 PM
INMY01TA's Avatar
Ya, they never rust out. Most old Mustang guys replace em once or twice then switch to Borla.
By Brett Foote | 2026-06-04 05:00:17
