mod list running out of ideas
i have a 2001 ta ws6 a4 car that i have been working on but i made a list of all the bolt ons i want to do if anyone can add anything please do also any suggestions about anything ?
lid
filter
ported MAF sensor
smooth bellow
ported throttle body
throttle body bypass
MSD wires
NGK plugs
synthetic motor oil
160 degree thermostat
long tube headers
good Y pype
stall converter
under drive pulleys
lid
filter
ported MAF sensor
smooth bellow
MSD wires
NGK plugs
synthetic motor oil
long tube headers
good Y pype
stall converter
under drive pulleys
Underdrive Pully, you could change ur MAF to TSP's 100mm one when it comes out, Electric Water Pump, and MSD coil packs if you absolutely have nothing else to do and you have lots of extra cash. If youve got the stock 2.73's, some 3.73's would do you some good. And if you plan on doing H/C you could upgrade youre intake to a FAST 92mm and throttle body when it comes out, or you can just get the 90mm, shouldnt be too much of a big diff unless youre running big cam/heads
true, but if has absolutely nothing else to do and a spare $620 to spend he could buy them which is a complete rip. and as for the 100mm maf he could get one if he plans on running a big H/C later on
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That 100mm maf is too ridiculous. Run a Delphi/ZO6 and that will hold down major power. I don't know why your talking about monster over-sized parts when the guy said that he could not think of any more mods and heads and cam are no where to be found in his post. Even then, it would take forced induction with 15-30#'s of boost to even think about changing....and at that point you would be looking at carburated setups and or BS3.
Tough Mudder
2001 ws6 transam red A4
1970 GTO orbit orange Judge 400cid
1969 GTO black 400cid
1971 GTO blue 400cid
1970 GTO convertible red 400cid
I'd look into getting a custom made 400cid just to stay consistent.
i still say stick with the normal bolt on's, and gears like camaroz28aquino said...and get a tune, you will like where you are sitting..if you need more, then look into h/c...still need more..bigger cube or s/c that bird or both!
yeah i have looked for parts for stroker motors way out of my price range right now but the reason i didnt put heads and cam on there was because i was just thinking about bolt ons only
set up a plan of mods man...gotta do it in stages if you are on a budget like the majority of us...start with one area, such as, engine, then break it down in stages...stage 1:exhaust, stage 2:intake ect ect..that is what i am doing
My suggestion would be to lose the ported maf. My car gained 7 hp on the dyno from switching from my ported maf to a stock one that was only descreened. The dyno operator suggested it. So I went along and was glad he pointed it out. If you port or replace the maf ends your car it will not measure the incoming air correctly.
lid
filter
ported MAF sensor
smooth bellow
MSD wires
NGK plugs
synthetic motor oil
long tube headers
good Y pype
stall converter
under drive pulleys
lid
filter
ported MAF sensor
smooth bellow
MSD wires
NGK plugs
synthetic motor oil
long tube headers
good Y pype
stall converter
under drive pulleys
I just did these the exact same mods except for the stall, I have an M6.
Deffintly get a dyno tune, I took mine to get dyno'd and my A/F Ratio was way off. It was between 17-18 and should be around 12.8 range.
My first run was 306hp/315tq! Bad, very bad, we did another run, same thing, then Mike tricked the MAF with some type of tuner and the car put out 350hp/355tq on the last run!
I am going back down today so he can do a full dyno tune. At first, I was trying to get away w/o having to do this, but after all this work, that 50hp diffrence is what it is all for. I know each car is different but the tune is a must do with the combo of all these mods. I had descreened my MAF and I think this was the possible culprit of my A/F messup, and if you ported yours, you may experience the same problem.
