How to Re-Fill Coolant
Old 06-28-2003, 10:48 AM
Ferocity02's Avatar
Default How to Re-Fill Coolant
I drained out the coolant to install some gauge senders. I drained it out of the radiator and out of the block. Can anyone guide me on how to re-fill the system with coolant? I checked the manual but it was pretty scetchy. And, is it safe to add a bottle of Water Watter? Thanks
Old 06-28-2003, 11:01 AM
Nasty N8's Avatar
Default Re: How to Re-Fill Coolant
Fill system with engine off cap it then run it til the t-stat opens it will suck down what it needs let it cool some fill and repeat. yes you can use Water Wetter.
Nate
Old 06-28-2003, 12:14 PM
Ferocity02's Avatar
Do I fill the radiator or the tank next to the battery? Thanks
Old 06-28-2003, 12:27 PM
4thGENRETARD's Avatar
The radiator
Old 06-28-2003, 02:46 PM
Doc
Doc's Avatar
www.installuniversity.com has a nice reference w/ photos
Old 06-28-2003, 04:25 PM
Smoke_Ford's Avatar
Thats a cool site, remember to use a 50/50 mix of water and coolant.
Old 06-28-2003, 09:58 PM
WS6 GreeN's Avatar
I wouldn't recommend drivin it far before you know its full. I recently put in a tstat and only lost a minimal amt of coolant, but air got in the system and caused my temp to rise VERY fast to 230+. Just keep checking the level.
Old 06-29-2003, 02:09 AM
Mike K.'s Avatar
just make sure you get all the air out of the system as best you can, the installuniversity site has this documented well.
Old 06-29-2003, 09:07 AM
Restricted User
2001 Pewter WS6's Avatar
It will take a while to burp all the air out of the system. Make sure you check the level before you drive it for the next couple times. I had to top mine off 4 times before it stayed full...
Quick Reply: How to Re-Fill Coolant
