HELP! in the middle of ps pump change
Old 12-27-2007, 02:16 PM
UnZFeat'd's Avatar
Default HELP! in the middle of ps pump change
Hey guys im in the middle of changing out my power steering pump. Im following a haynes manual i have and ive drained the coolant, took off the belt, and removed the lid and intake assembly, but now it says i need to take the power steering pump pulley off. how do i do this? it seems like it would be impossible because of the hoses to the radiator and the radiator itself. do i really need to take that all out?
Old 12-27-2007, 02:26 PM
EarlSS's Avatar
When i changed my ps pump i didn't any coolaint or anything. I just took the three bolts out that hold it on. I didn't take the pulley off until i had the pump off the car. I had to use ratchet wrenches plus i had to remove one bolt from undernieth the car because everythings so tight around the pump.
Old 12-27-2007, 02:36 PM
UnZFeat'd's Avatar
where are the 3 bolts located?
Old 12-27-2007, 03:16 PM
1badA3Z's Avatar
They are behind the pulley,but u can walk it off with the right wrenches!
Old 12-27-2007, 03:23 PM
UnZFeat'd's Avatar
have you done that? can you explain to me how you did it?
Old 12-27-2007, 03:26 PM
TheLS1Kid's Avatar
Advance Auto or Autozone shoud sell a p/s pulley remover.
Old 12-27-2007, 03:28 PM
UnZFeat'd's Avatar
they do, but in order to fit it in i would have to take the radiator out. im looking for a way where i dont have to do that... if i can
Old 12-27-2007, 03:32 PM
travisnd's Avatar
you don't need to remove the radiator to use the power steering pulley remover, there is enough room....
Old 12-27-2007, 03:55 PM
UnZFeat'd's Avatar
i dont believe there is. i just tried it and its about an inch and a half too long, even when i removed the hoses
Old 12-27-2007, 04:20 PM
travisnd's Avatar
I've taken my pulley off many times without removing anything, just had to move the power steering cooler alittle....
Old 12-27-2007, 04:46 PM
TheLS1Kid's Avatar
I've never heard of having to remove the radiator to use the tool.
Old 12-27-2007, 05:28 PM
UnZFeat'd's Avatar
nevermind, the people at pep boys sold me the wrong tool. i went to autozone and they rented me the power steering pump pulley puller and it looks like itll fit now. but does anyone still have any pictures of it to aid me? Thanks
Old 12-27-2007, 06:13 PM
UnZFeat'd's Avatar
ok scratch that... i just broke the tool autozone loaned me. that pulley is not coming off. how do i get the pump off without taking the pulley off? or how do i pry the pulley off?
Old 12-27-2007, 06:37 PM
10SecDreamer's Avatar
look at ls1howto.com website, under cam swap. It shows pictures of where the bolts are to remove the pump without taking off the pulley. There is 3 of them, just use an open end wrench.
Old 12-27-2007, 06:55 PM
UnZFeat'd's Avatar
right, so in order to do that i need to take my water pump off? anyone else? before i plunge into a water pump deal?
Old 12-27-2007, 08:06 PM
Fratsit's Avatar
The only way that I am aware of is removing the waterpump. I am right in the middle of my head swap and had to remove the water pump to get a clear shot at the bottom PS pump bolt.
R/
Frat
Old 12-27-2007, 09:41 PM
DONAIMIAN's Avatar
gearwrenches are your friend.
Old 12-27-2007, 09:58 PM
Fratsit's Avatar
A very dear friend.
Old 12-28-2007, 05:25 AM
Galen's Avatar
Autozone PS pulley puller. Tighten and then tap the pulley with a rubber mallet. You will hear a pop, then the tool will be loose. Tighten again ane repeat with rubber mallet. It takes a while, but is possible. Don't tap the top of the pulley where the belt goes, but on the face of the pulley. Just changed mine last week, piece of cake!
Galen
