Fra
Old 12-27-2007, 11:02 PM
99puterss's Avatar
Default Fra
when you are doing the FRA mod and you have to cut the plastic piece thats in between your radiator. I just removed that whole piece. will that be okay or does it need to be there
Old 12-28-2007, 02:34 AM
bryan04h's Avatar
installuniversity.com that will show you everything you need to know....you should be fine because you have to do that when you install a ssra or ftra...but i don't know if you were suppose to remove the whole thing for a fra
