Professional Products 85mm Intake Swap
Moderator
Seems like it's going OK, the new gaskets plus pan-head valley
bolts have the intake sitting comfortably on the gasket. The
"update kit" works fine for the brake booster and accessory vac
lines, and my custom fuel plumbing fits up OK to the stock
snap-connector. The only thing I'm having trouble with is the
MAP sensor, the harness seems like it's a couple of inches short
for the new location. I plugged the MAP into the smooth bore
centered on the back of the manifold.
Anybody run into this? I'm thinking I'll cut the pigtail wiring
and MAP connector off the spare harness I have and lengthen
it, but if there's a simple trick I'd like to know. Could unwrap the
harness and break it out for more slack I guess, but not sure
how much that'd give me.
