need to quiet down my true duals alot
Old 01-31-2008, 12:37 PM
badaz28's Avatar
Default need to quiet down my true duals alot
I have Pacesetter LT's, no cats, and 12in bullet mufflers dumped. I need to make it really quiet and not spend alot. The reason is my HOA.
The shop that built my duals suggested that I switch to 18in bullets and extend the duals under the axle to the rear. I am just not sure if that will be quiet enough. I was also thinking of keeping my current bullets and adding another pair of 12in bullets in the extentions to the rear, but not sure how it will sound with 4 mufflers. What do you guys think?
Old 01-31-2008, 12:56 PM
DirtyJohn's Avatar
I've got 4 bullets in my duals and its quiet as hell.
People have commented on how smooth it sounds.
I also have cats though, those will quiet it up a touch, which I thought a shop wouldn't touch a car without cats?
Old 01-31-2008, 01:44 PM
plaf713's Avatar
two chambered 40 series, or magnaflow mufflers, both will sounds good, im sure there are more out there
Old 01-31-2008, 01:50 PM
defenestrate's Avatar
im thinking about going with two magnaflow mufflers, im in the same boat you are
Old 01-31-2008, 02:12 PM
ROCNDAV's Avatar
I was thinking of going with four mufflers as well.
Old 01-31-2008, 02:15 PM
speed_demon24's Avatar
I'm in the same boat as you. I'm currently running 12" spiral flows. I'm thinking about switching to 18" twisters and some magnaflow 59959 cats. I already have it run out the back. I'm more annoyed by the smell than the noise though.
Old 01-31-2008, 02:20 PM
MarylandSpeed's Avatar
Best bet would be a straight through Magnaflow
Old 01-31-2008, 04:05 PM
1320 killer's Avatar
I have a custom td set up. Kooks lt's 3 inch mandrel bent X pipe 18 inch bullets over the axle and magnaflow ar the rear bumber. and my **** is loud as hell.
Old 01-31-2008, 04:35 PM
LS698ta's Avatar
add a cat or 2?
Old 01-31-2008, 04:37 PM
00cls1camaross's Avatar
get rid of your TDs.... you should have known they were going to be loud.
Old 01-31-2008, 04:58 PM
SladeX's Avatar
toss some mufflers on. I put some 3 inch mufflers on mine since my TD's go over the axle and out the back.
At the low RPM, there's a nice bass tone to it. Not loud. At WOT, she screams out the back. Better for it to be aimed at the traffic behind you than enduring it for long drives in the car with you.
Old 01-31-2008, 08:10 PM
Eskimo's Avatar
I think the most cost-effective method would be to extend the pipes out the back, and add a dual muffler at the back as well, leaving your bullets.
Hint: There are a few in the FS Section for not too much $$
Old 01-31-2008, 08:46 PM
GTObsessor's Avatar
Here's the quietest setup I can think of: longest Mangaflow ovals (the thinnest you can find on Summit) after the X pipe that you can fit, then run it under the axle into 2 Hooker Aerochambers (probably the 18" ones). That should be nice and quiet. I would do that now but I don't have the $$$ and my Dynomax Ultra Flos are relatively quiet so I'm just gonna stick some magnaflow ovals after the X.
Old 02-01-2008, 06:44 AM
teke184's Avatar
the standard magna flow 4x9s should do the trick.
they quieted my cammed motor down alot.
search my name, i've posted vids with straight pipes and then with mufflers....comparison is drastic...you almost can't hear the car run with the mufflers on.
Old 02-05-2008, 10:31 PM
badaz28's Avatar
Do you mean some magnaflows in place of my current bullets or add them in the rear?
Old 02-05-2008, 10:38 PM
bmxer8699's Avatar
godamn, that smell is terrible, you still smell it with the exhaust out the back?
i think im going to get some cats, and some 12" twisters, maybe longer, i have no idea yet. ill spend money when summer hits.
Old 02-05-2008, 10:44 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Old 02-05-2008, 11:11 PM
Unless there is a strong tail wind it's terrible when I'm stopped. If I back my car into my garage my eyes start burning and watering. My cam does have a decent amount of overlapt to it so I'm sure that plays a role in it.
Old 02-06-2008, 02:20 AM
mukyluk's Avatar
running 3" TD's no cats.
i usually only drive in 2nd and 3rd in my neighborhood if its in the "quiet hours". but them telling me to tone my car down is like me telling anyone with a loud annoying dog to have its voice box removed. f**king dogs barking all night :shakes fist:
Old 02-06-2008, 03:30 AM
somws6bird's Avatar
Hey why not just get those cone inserts, that you can probably put in the bullets, should tone it down a bit. There not that expensive.
Quick Reply: need to quiet down my true duals alot
