Accessory and Swap Questions?
Old 02-06-2008, 10:45 AM
QuickZ28's Avatar
Default Accessory and Swap Questions?
Alright heres the story.....Working with a Lq4 6.0 motor swapd into a thirdgen!!
Im swaping over all the accessories and just have a few questions! Everything im swaping over is from a 98 Ls1...
First, the oil pan.....This is a direct swap bolt on correct? I ordered a new GM 98 Ls1 oil pan/windage/pickup so i can put it in.....Am i missing anything else?
Second, The accessories..... I bought a new PSP w/ brackets, cranck pulley, alt w/ brackets , tensioner, w/p all from a 98 ls1........Will i run into any clearences or issues bolting it up? does this swap right over?
Also, i dont know if this is the right section but im wanting to do a stock cam swap....Meaning a cam from a Z06 or Ls7!
Which would work better w/o spending alot of money? I just want a little more power outta the motor w/o spending 400$! Im also using a th350 with a 3000-3200 stall!!
Is the ls7 cam too much? Or will it not work? If i swap a Z06 cam, do i have to swap over the pushrods and springs?
Please any help and feed back would be greatly appriciated!! Im a newb when it comes to Ls series motors and what will work with what!
Old 02-06-2008, 10:54 AM
AINT SKEERED's Avatar
YOU will have to drill one hole in the iron block for the alt. to work. It will have 2 bolts already in and you just drill the 3rd one . should not be bad.
all else should be fine.
Old 02-06-2008, 01:19 PM
QuickZ28's Avatar
Thanks!!
Old 02-06-2008, 02:46 PM
sroach20's Avatar
i did not drill the 3rd hole and the alt will not move at all. mine has been that way for 6 months. its only needed for peace of mind.
