people with fast 90 mm throtle bodies please enter
Old 02-10-2008, 02:45 PM
volksmech1's Avatar
Default people with fast 90 mm throtle bodies please enter
just got my fast 90mm set up on and the only kink is that the throtle body seems to stick a little open. i have adjusted the throtle cable. that is all okay, but you can feel how it seems to stick a little bit open. would knife edging the throtle blade help any? or is this something that will just work its way out eventually? anyone else have this problem with the fast 90mm throtle body?
Old 02-10-2008, 02:58 PM
blownws6_nc's Avatar
My buddy has that same tb and the same problem, he's selling it, and going to by a different brand.
Old 02-10-2008, 03:13 PM
volksmech1's Avatar
so he didn't make any attempt at fixing it? or is he getting rid of it after trying a **** ton of stuff to fix it but still no end result?
Old 02-10-2008, 03:17 PM
BURN'EM's Avatar
Remove the throttle blade, and twist the shaft back to place the spring in more bind. This will allow more pressure to shut the blad when not under acceleration.
Old 02-10-2008, 03:22 PM
volksmech1's Avatar
awsome. thanks
Old 02-10-2008, 04:01 PM
kkslds's Avatar
I put an extra throttle return spring from the little pin that sticks out to a hole in the radiator shroud. Seems to work for me
Old 02-10-2008, 04:32 PM
volksmech1's Avatar
i was thinking about doing that but it would really look like ***, so i was trying to find a diffrent way of doing it
Old 02-10-2008, 07:30 PM
themack56's Avatar
get rid of it, buy a nick williams 90 mm tb, i had the fast, i sold it and bought a nw's,
Old 02-10-2008, 07:52 PM
iamsickofitall's Avatar
doing this works perfectly
