Car is running weird, Surges, creeps, and cam's lope is.....
Old 07-12-2003, 09:14 PM
needmoremoney's Avatar
Default Car is running weird, Surges, creeps, and cam's lope is.....
My H/C is all done. Specs in sig. I drilled the T.B. hole out to 1/4 inch, and now the car idles to high, and the cam lope sound is not as loud as before. This is driving me nuts. Now that I drilled the T.B. hole, can I still use my T.B as a core? Also, Do you think I would gain ANYTHING is I changed my SLP lid, to the new TSP LID? Thank you
Old 07-13-2003, 07:27 AM
redz_02's Avatar
Default Re: Car is running weird, Surges, creeps, and cam's lope is.....
any tunning. As for the porting, you can talk to bauer personaly, he'll tell you whats up on the hole.
Old 07-13-2003, 07:18 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Might check with a GM dealer and see what just the TB blade costs and replace the old blade with a new undrilled one.
Call SDPC over there>>>>>>>>>>>>>>>>>
and see what the price of just the blade is, SDPC will probably be cheaper than the typical dealer.
Old 07-13-2003, 08:47 PM
DaleMX's Avatar
You can glue the hole shut with some JB Weld then redrill it to the correct size. Rough the hole up and make sure it's super clean then give the epoxy 24 hrs to cure before you sand and drill it.
Old 07-14-2003, 07:30 PM
DONAIMIAN's Avatar
THat or get someone to weld it up for you.
