Vibration at idle in all forward gears
Just noticed a vibration this morning in my 99 camaro, V6, automatic. Only occurs in the forward gears. Also feels like the engine is losing power in acceleration. Engine is smooth as silk in reverse. Any ideas?
Thanks for the help. Engine is all stock except for an SLP:confused manual fan switch.
Moderator
Maybe a motor mount problem, something that loads
when the powertrain rolls one way and unloads the
other, under the back-torque? Might be something
as simple as an exhaust - body interference that is
only shown under load. No banging under harder
acceleration?
acceleration?
No, no banging under acceleration. Will check out the items you mentioned when I get back to the house today. Use this as my "going to work" car and it has been doing great until now. Always been smooth...oh well. Thanks for the reply.
do you know where it is coming from (front or back of the car) could be just a heat shield thts finaly worked its way loose had one do that on my car after about 67000 miles only did it when i was pulling out of the driveway and my neighberhood but once i got up to speed it quit
Feels like it is coming from under the gearshift and just forward. Just checked the exhaust, everything seems solid. Sorry for the question, but where to find the engine mounts? When I let off the accelerator, hear a clunk.
Thanks again.
Thanks again.
