rockers for trickflows?
I have a set of trickflow heads and was wondering what ratio rocker I will need for them? I was guessing 1.7 but I also thought that since they need a 7.5 pushrod they may need a different ratio. Thanks for the help.
Well...depending on where you got them from they should come with new pushrods,i got mine from TEA and they came with the heads.
What ever rockers you run make sure you check swipe pattern before determining pushrod length. yella terras requie the shim for tfs and a different pushrod than comes standard normally espcially if you get them milled and different gasket thicknesses.
Top Fuel has custom pushrod length for his setup also I hand to shim harlands to get the right pattern I believe it was a .060 shim
i didnt need to shim mine. after u shimmed them did they interfere with the valve covers at all? i have harlards also.
you have clearence with harlands (never had any touch), but its interesting I have setup abut 7 cars with harlands and all had a less than ideal swipe pattern. I wonder if they changed the valve install height or or raised the rocker bosses
