Egr! Air!
Old 03-06-2008, 03:26 PM
00_transam_vert's Avatar
Default Egr! Air!
When Removed; And not tuned out, They throw codes, right? What causes them to throw codes? Is it because the computer tries to turn them on but notices that it cannot?
Old 03-06-2008, 03:57 PM
go-t's Avatar
Yes they throw codes... and I believe it because there not plugged in any more.
Old 03-07-2008, 07:32 AM
Ok, does anyone know if putting a correct OHM resisitor in the end of the connector would work? I know thats all the skip shift eliminators are.
Old 03-07-2008, 09:02 AM
Michael02hawk's Avatar
I suggest doing it the right way, get the codes disabled in the PCM with a tuner.
Old 03-07-2008, 11:01 AM
go-t's Avatar
Yea just get them eliminated most likely your are putting parts on anyway so just get it tuned and have them turned off
Old 03-07-2008, 07:08 PM
01ssreda4's Avatar
or you could cut the wire to your service engine light. then.....no more light.
Old 03-07-2008, 07:41 PM
Pntbll309's Avatar
The air will not throw a code unless you pull the fuse for it out. The EGR will throw a code tho.
Old 03-07-2008, 10:13 PM
RooRnZ28's Avatar
well if there is a code, will the car run like ****? or will the light just be on because of no air?
Old 03-07-2008, 10:16 PM
jetlag's Avatar
Ignore the code, it won't cause any trouble.
Old 03-07-2008, 10:31 PM
go-t's Avatar
The only time that you have to worry about SES light is when it flashing thats when the ***** hitting the fan!!!
Old 03-07-2008, 10:45 PM
King Nothing's Avatar
hahahaha
Old 03-07-2008, 11:00 PM
unbroken's Avatar
1" piece of black electrical tape-problem solved.
Old 03-08-2008, 08:24 AM
haha those are all viable solutions, the reason i don't get them tuned out is because there isn't a competent shop within 6 hours of where i live. But no one knows if my resistor idea will work?
Old 03-08-2008, 10:16 AM
waldershrek's Avatar
Put it this way, I have never heard of anybody doing it and I'm sure if it worked somebody would have discovered it by now. Maybe you should have thought about this a little more before you went ripping stuff out.
Old 03-08-2008, 12:04 PM
SS#2906's Avatar
I agree!
Old 03-08-2008, 12:06 PM
go-t's Avatar
Buy Hp Tuners And Do It Your Self!!
Old 03-08-2008, 01:04 PM
This is stuff im thinking about before i start doing anything, I thought maybe somone that might know a little more than i do would be able to help. Based on your comment; you obviously don't. So unless you've got somthing constructive to say, allow me to 'put it this way' and keep your smartass remarks for yourself.
Old 03-08-2008, 01:07 PM
Yes, this is the route i will be taking eventually. My TA isn't my only project and is kept primarly for a Summer daily driver. This is just somthing i was curious about and that maybe somone had done this temporarily between waiting time for a tune.
Old 03-08-2008, 01:15 PM
go-t's Avatar
What other projects do you have? Pics?
Old 03-08-2008, 02:56 PM
I've been working on an 81 TA for quite a while now, I've got an 81 Chev shortbox 4x4 that is an on going project and i recently resqued a 79 TA and a 76 TA from an old farm yard.
