0.38(20K) Ohm Resistance On A Stock Spark Plug Wire?
is that normal? i had 8 msd wires and one went bad - the 7 that are good test at 0.02-0.03 on the multimeter when it is set to 20K
i got one stock cable that i tested and it read 0.38 at 20K on the multimeter - should i go ahead and put this one in? or should i find a new single stock wire? or try to find a single msd wire?
thank you
thank you
Tech Resident
You can use it, but all it means is that the stock wire carries A LOT more resistance than the MSD wire. Since current is voltage divided by resistance, it means you get less current through the stock wires, making for a less powerful ignition system. MSD wires are much more 'efficient' than stockers, if you will.
