? about fast intake,injectors,cam?
Im in the process of swapping out my bbc for a and its going in this
I was wondering what would be some good bolt ons? I was toying with the idea of a fast intake 90mm tb or a typhoon or something like that (any insight) Also id like to find a good size cam and injectors...Any replys would b greatly appreciated im about to get my wings finally....
LS1 i assume? Depending on your budget id go headers/Cam/clutch(or converter it looks like) and start with that. If you can afford a fast and cam at the same time you'll def gain some power in the upper RPMs. As for the cam there are plenty of cams to choose from...if its a race only application id consider going to a solid roller setup...with a good set of heads you can really make some good power!
X2 The FAST won't gain you anything until you have the supporting mods to utilize the extra flow. Assuming auto I like the idea of a T/C too.
yeah its a lt1 im just trying to have better than stock hp and performance. I mean, I was worrying about doing the heads because i dont want to have to build the bottom end up. I dont want to put heads on it and end up blowing the bottom end out of it. Its a auto transmission. Anything That would Aide me in any hp and torque gains would be greatly appreciated
I wouldn't go hog-wild up top without a stout rotating assembly.....but that's just me.......
