True Dual Help Needed!
Hey guys, I am in the process of installing a set of Pacesetter LT's and the Texas Speed true duals. I am having a serious ride height problem, I only have about 2.5" of ground clearance under the mufflers. I have had everything out and apart about a dozen times, and this is the best I can get. The mufflers are all the way up aginst the floor of the car, and I know I have the X pipe right side up (That was my mistake the first time.) The car is lowered a little 1.5" in the back I beleive. It is the Hotchkis kit if that helps. Is this the normal ride height to expect or am I missing the secret to this? Any help would be appreciated.
Thanks in advance!
Also I did search through the photos and didn't see anything differant than what I had done.
Thanks in advance!
Your problem is that your car is lowered in the back. I have the true duals and my pipes are only about 3-4 inches off the ground and I'm stock height. It's gonna be expected for the exhaust pipes (especially 3+ inch pipes) to be low to the ground with these cars. There's nothing you can really do except raise it back up. Just be careful going over bumps and you should be OK. I've never had an issue with my pipes, but they do scrape a tiny bit if I go over a speed bump too fast.
