coolant temp sensor help!
Old 07-26-2003, 07:08 PM
purevilss's Avatar
Default coolant temp sensor help!
Does anyone have advice on a quick way to unthread a coolant temp sensor that is broken off inside the head?
Thanks,
Scott
Old 07-26-2003, 07:49 PM
wrencher
wrencher's Avatar
Default Re: coolant temp sensor help!
Drill & easy out, prolly your only option.
Old 07-26-2003, 10:19 PM
purevilss's Avatar
Yuck, hoping to hear something better. Well no drilling will be required since the guts all came out with the connector end. I just have the threaded section in the threads of the head to get out.
Old 07-26-2003, 10:36 PM
01redws6ta's Avatar
I've had luck using a small deburring bit to grind as close to the threads as possible without damaging and then using a small chisel to split the threaded piece in half or at least break it off piece by piece. Be careful not to damage the threads too much. You'll then want to tap the threads out and use some teflon tape or liquid on the threads of the new sensor to ensure a good seal. Good luck!
Old 11-26-2007, 05:57 PM
PipeJones's Avatar
I used an easy out and it came right out. $12 local part store.
Old 11-26-2007, 06:17 PM
2001NBMZ28's Avatar
Yikes this is an old thread.
Quick Reply: coolant temp sensor help!
