How To Wire Tach??? Autometer Aftermarket 5"
Old 05-10-2008, 04:44 PM
sixpack_2_go's Avatar
Default How To Wire Tach??? Autometer Aftermarket 5"
i needed an aftermarket tach for my car because i will be spinning higher RPM's when i put my cam in. my buddy gave me a 5" Autometer sport comp with a shiftlight out of his 69' camaro(has distributor). my question is how can i wire this up to my 2002 camaro LS1 with a plug on coil igition? do i need some kind of adapter?(if so,where can i find one for cheap?) i have heard something about putting it in 4cyl mode?
Old 05-10-2008, 04:46 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
wire to pin 35# i believe on the pcm, and then switch the tach to 4cyl mode
Old 05-10-2008, 04:50 PM
SweeTbone's Avatar
You want to wire the tach lead to Pin #10. It's a white wire on the lower connector of the PCM. 99-02 was #10, 1997-98 used pin #35. And 4 cylinder mode is correct.
Old 05-12-2008, 06:16 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
yup the green wire off the tach goes to PIN #10 on the PCM. Red to a key on power source, black to a ground and white is for the light inside the tach(i used the gauge fuse inside the car)
Old 10-20-2008, 04:38 PM
camarostripes96's Avatar
Location: Academy,Tx (home of temple/academy Drag Strip)
ok what pin does the green wire go on , in a 96 trans am?
Quick Reply: How To Wire Tach??? Autometer Aftermarket 5"
