FAST 92mm throttle body bolts
Old 05-24-2008, 12:11 PM
Martin HD-28's Avatar
Default FAST 92mm throttle body bolts
The instructions say 4 M6 bolts but the package has 2 bolts longer than the other 2. Where do i position the 4? After install of the 92 combo, my throttle is way too high, I thought the position of these may effect the throttle?
Old 05-24-2008, 04:31 PM
99mongooSS's Avatar
that or you have an intake or vacum leak somewhere.
Old 05-26-2008, 05:11 PM
Has anyone installed the FAST 92 T/B? How do you know where to position the 4 bolts? 2 are longer than the other.
Old 05-26-2008, 09:33 PM
35th SS's Avatar
Im in the process right now on my Blk one.ran into a snag.gotta get new eng.knock sensor wire harness tomorrow.will take a look on mine and will post back in a bit.
Old 05-31-2008, 11:46 AM
TTT, I still don't know why there's 2 bolts one size and 2 another size for the 92mm Big mouth. Anyone?
Old 05-31-2008, 05:27 PM
35th SS's Avatar
okay.mine is all installed.in the bag you have 2 short ones.those goes on the bottom of the tb.you have another 2 bolts in there little longer than the 1st one I mentioned those goes on the top of the tb.lastly the last bolt goes on top of the tb right in the middle it goes through from the front to the back of the tb with a nut behind it.these are all allenhead bolts.thiers two very long bolts in there with thick flat washer also.those are for the 92mm intake.
Old 06-01-2008, 02:15 PM
I've only got 4 bolts connecting my TB to the intake. I didn't have any left over that I can think of but not having the top center bolt might explain the high idle and loud suction of air at start up. Is the top center bolt the same as the other 4? I just don't have it.
Old 06-01-2008, 10:13 PM
35th SS's Avatar
I believe its the same lenght as the 2 bottom bolts.just go to any hardware store and grab a stainless steel one with a nut behind it.
Old 06-02-2008, 05:53 AM
Thanks for the help!! I love this site.
Old 06-02-2008, 02:12 PM
Hey guys, I dropped my car off at Automotion in Louisville this morning to get a re-tune done after the 92/92 combo install. I told and showed him my issue with the loud suction of air for the first 30 seconds and the idle being all out of whack. For whatever reason, I never considered the source of the problem to be the throttle cable bracket!! An hour or so after I dropped it off, Charles from Automotion called to say he found that the throttle cable bracket was causing the cable to have too much tension on it causing it to keep the throttle body open just enough to create the suction, after the initial 30 seconds, the Idle Control Sensor learned the system and would adjust itself to control the vacuum!! It makes sense to me but I just never considered looking at the bracket, he drilled it out a little bit and lessened the slack on it and it cleared right up!!!!
Quick Reply: FAST 92mm throttle body bolts
