LS1's 98-00 vs. 01-02
Old 06-04-2008, 01:08 PM
downtown_ss's Avatar
Default LS1's 98-00 vs. 01-02
I have heard there is a difference in the 98 to 00 LS1s towards the 01 and 02 Ls1 motors. What is the difference in the 2??
Old 06-04-2008, 01:19 PM
mite53's Avatar
There is actually quite a few things different, between them. 01 and up have the ls6 intake, they have a different cam from the the lq9 truck motors to give better low end torque and better emmissions,slightly bigger injectors i think, there is no egr, the throttle body's are different thats all i can think of for now, im sure someone will add other differences if there are any.
Old 06-04-2008, 01:52 PM
02silvaZ's Avatar
dude, check out the FAQ sticky above, all of this has been covered numerous times, it has good info, this will get locked very soon
Old 06-04-2008, 01:58 PM
Bad Blue WS6's Avatar
98/99's have the worst flowing heads (853's)
i think 98, 99's and 2000's have bigger cams than the 01/02's
TB's are different 98/99 have a differnt sized TB cam..
98/99/2000 have LS1 intakes stock,,01/02's came with LS6 intakes
rims!
Old 06-04-2008, 02:43 PM
primer84z's Avatar
for being in the sticky people always post up bad info. 806 heads are on the 98's...
Old 06-04-2008, 02:53 PM
My bad,,,i thought 853's were on both early years,,thanx for the correction.
Old 06-04-2008, 03:03 PM
twitchtwice's Avatar
he's new here, give him a break.
Old 06-04-2008, 04:24 PM
primer84z's Avatar
no problem dude, I wouldnt have known if I hadnt had a 98 and a 99.
Old 06-04-2008, 04:43 PM
Super Speed's Avatar
some 00's had upgraded rod bolts while some people say 01-02's came with them some later 00's also came with 243' heads as well
Old 06-04-2008, 05:01 PM
jmdale1984's Avatar
To the best of my knowledge... 243 heads didn't even exist until 2001 (when they were introduced on the Corvette Z06) and they were never put on f-bodies. Wouldn't suprise me if a couple 01-02 f-bodies/base y-bodies got them, since GM seemed to use LS6 parts whenever they ran short on LS1 parts.
98 - 28 lb injectors, LS1 intake, poop heads, EGR/AIR
99 - 26 lb injectors, LS1 intake, EGR/AIR
00 - 26 lb injectors, LS1 intake, AIR/Revised EGR, revised exhaust manifolds
01 - 28 lb injectors, LS6 intake, AIR only, a couple had LS6 blocks, smaller cam, upgraded hydraulics (M6 only), revised exhaust manifolds and MAF sensor
02 - 28 lb injectors, LS6 intake, AIR only, 10% had LS6 blocks, smaller cam, upgraded hydraulics (M6 only), revised exhaust manifolds and MAF sensor
That's the best I can do off the top of my head. I could be off on a couple things, but I think that's pretty accurate.
Basically, 98s got screw on heads and intake, 99-00s got screw on intake and injectors, and 01-02 got screwed on the cam. 01-02s always put down the best dyno numbers stock.
Old 06-04-2008, 08:00 PM
02silvaZ's Avatar
he's been here a year bro!
Old 06-04-2008, 08:01 PM
02silvaZ's Avatar
and i wasnt tryin to be a *****, just tellin him where to look
Old 06-04-2008, 09:36 PM
Trunion King
bene's Avatar
later model 2000s and 01-02 LS1 have 241 heads.
Old 06-04-2008, 10:43 PM
kidcamaro98's Avatar
how can we find out if we have a LS6 block??
Old 06-04-2008, 10:48 PM
im guessing if it was later on in the year 02 or if it was built on tuesday-thursday. haha jp
Old 06-05-2008, 01:29 PM
5_02ls1's Avatar
the heads really aint that bad on 98s ....97 98 had perimiter bolt valve covers...
but the heads arwent as bad as most let on....
Old 06-05-2008, 05:49 PM
Bulldog0082's Avatar
How can you tell on a 2000 what kind of heads you got?
Old 06-05-2008, 06:08 PM
Correct
Old 06-05-2008, 06:10 PM
King Nothing's Avatar
pop your hood and look on the corner where the valve cover seal and the head meet and it'll have a casting number. my 2000 SS was actually built in sept of 99 so i have the 853 heads . . . course some 241's are sittin in my garage right now
Old 06-05-2008, 06:24 PM
02silvaZ's Avatar
my 2000 has 241's
Quick Reply: LS1's 98-00 vs. 01-02
