Greddy Catrch Can installed pics setup OK?
Old 08-13-2003, 07:14 PM
TaTommyWS6's Avatar
Default Greddy Catrch Can installed pics setup OK?
Well, I just finished installing a Greddy oil catch can in my car since I am consuming oil lately (macs, cam, etc...)
Anyway, I did not realize how heavy a piece this was. The best place I could find for it was on the drivers side near the fuse boxes. It is really tight, doesn't rub, but it is a little far away from the other side. I used four feet of hose for each connection (8 feet total). I pulled it off and there is plenty of suction, so it this ok? It seems good to me, but I did not see any pics of others mounting it there. Thanks!
Tommy
Old 08-13-2003, 09:54 PM
NightHawk's Avatar
Default Re: Greddy Catrch Can installed pics setup OK?
Looks nice.
As long as there's still good suction and it doesn't rub on anything, why the hell not?
Is it attached to anything or just wedged in there?
Old 08-13-2003, 11:24 PM
TaTommyWS6's Avatar
I made a thick rubber boot it fits into. It is very tight. You have to really pull hard to get it out. It's not going anywhere!
Thanks.
Tommy
Old 08-14-2003, 12:10 AM
SScam68's Avatar
What did it cost you?
Old 08-14-2003, 06:38 AM
TaTommyWS6's Avatar
$83 plus shipping. From http://www.optauto.com/
Old 08-14-2003, 08:09 AM
nc z28's Avatar
is that the 8mm or the 15mm? did you buy anything else to go w/ it? im getting ready to do this to mine.
Old 08-14-2003, 08:13 AM
TaTommyWS6's Avatar
If you want to place it where I did, then you need one 4ft piece of 3/8 inch fuel line ($4). The clear line (4ft also) in the photo came with the catch can. And that's it.
I bought the 9mm.
Tommy
Old 08-14-2003, 08:35 AM
nc z28's Avatar
thanks!
Old 08-14-2003, 08:44 AM
nc z28's Avatar
one last thing, how does this work? once it is full do you put the oil back in? also my car has heads and cam and i have to put a quart in it about every 1500 miles. when we did a header swap i had oil residue on my header ports and exhaust ports on the heads.2 of my plugs were oily as well. does this sound like the problems you had or something else? sorry for all the questions just trying to figure this out. thanks!
Old 08-14-2003, 08:48 AM
TaTommyWS6's Avatar
I guess you can put the oil back in if you want. It is a closed system so I don't think any moisture/dirt can get in. (There is a drain plug at the bottom of the can)
Yeah, it should prevent the oil from getting sucked out of the valve covers (or valley cover is using LS6 setup) back into the intake manifold.
I'll know more about as soon as I put more miles on it.
Tommy
Old 08-14-2003, 08:50 AM
nc z28's Avatar
cool! please let me know! i asked about putting the oil back b/c of my consumption problem. w/ this should it get better?
Old 08-14-2003, 11:12 AM
SloWhite's Avatar
Catch cans do not stop oil consumption. They will only keep it from getting into the intake.
Old 08-14-2003, 11:24 AM
LS1 JAY's Avatar
Do you want my old one for a NICE price? ls1jay@yahoo.com
Old 08-14-2003, 12:59 PM
Phil99TA's Avatar
I installed mine where the EGR used to be. I bought the Greddy universal bracket and just bolted it to the head using the original EGR bolt and some washers.
Old 08-15-2003, 07:15 AM
nc z28's Avatar
slowhite, what do i need to do about the oil consumption? like i said i have to put about a court in every 1000 miles. my car is an 02 w/ 20,000 miles on it. it started after my heads and cam instal. please help! anyone!
Old 08-15-2003, 07:37 AM
LS1 JAY's Avatar
It may be the rings! My '99 with 50,000 miles on it started blowing huge clowds of blue smoke after the Mac's went on (@ WOT only), it was using 1 qt+ every 1,000 miles also, I just had it re-built and the rings were GONE! I tried a GReddy catch can and it worked great for catching oil from the PCV line, but my problem was the rings. I now have the LS6 PCV system and the GReddy in the garrage, it works, but if you are using large amounts of oil (like 1 qt every 1,000 miles or more) it's not all from the PCV system trust me.
Old 08-15-2003, 08:07 AM
nc z28's Avatar
what is the ls6 pcv system? i called my chevy dealer and they said that the ls1 and ls6 used the same pcv valve. what else is required to get? ive been afraid thats what it is(the rings). how much did it cost you to get the rings fixed? would it be better for me to just get a 346 resleeved, balanced, blue printed, and forged bottom end from mti($3000.00)??? my car only has 20000 miles on it and im sure they wont touch it now b/c of the mods ive done. thats whats going to suck no warranty. but i guess thats what happens when you take risks!
Old 08-15-2003, 08:50 AM
TaTommyWS6's Avatar
The LS6 PCV systems means you are using the the valley cover (under the intake manifold) to suck the air out of the engine, as opposed to the vavle covers.
Yeah, what is involved with doing rings... Maybe I'm up next
Tommy
Old 08-15-2003, 10:07 AM
TaTommyWS6's Avatar
This article explains a lot about oil consumption issues on LS1/LS6s:
http://www.idavette.net/hib/02ls6/page5.htm
Old 08-15-2003, 08:37 PM
TaTommyWS6's Avatar
Well, I got oil in there already. I guess it is working!
Tommy
PS And I did not put too many miles on... Under 100
