want to order some jet-hot LT's, have a few newbie questions
ive been looking into getting some jet-hot LT's for my car (01 Z28, completely stock). my question, do these headers already come with gaskets/bolts/collectors/etc...? When they say "egr and air fittings available", do I need the AIR fittings (01's have no EGR, right?)? also, i read they bring the o2 sensor bung, will i need o2 extensions for the fromt o2's (rears are getting 02 simms)? sorry for all the questions, i really appreciate the help!
Re: want to order some jet-hot LT's, have a few newbie questions
ok well i heard of people stretching the stock o2s to run into the header without extentions. if not jet hot sells extentions for 30 bucks for a pair. if you have the predator they can delete the rear o2's and the thing that spits in extra fuel to cool the cats when they get hot, its another 5-7 hp. its almost worth getting the predator. you save 80 bucks on sims, get 5-7 hp from just deleting that one thing, and plus you can have custom tune for more power.
...and the thing that spits in extra fuel to cool the cats when they get hot, its another 5-7 hp...
i bought the hooker LT's and I am pretty sure they are the same as jethot. I am writing this because I went ahead and used the paper gasket that they supplied, I have had no problems with it "YET" so unless people are having serious problems with leaks I would go ahead and use the paper ones supplied. I also used the stock bolts makes install go much smoother!
