ASP underdrive pulleys
Well it's not the easiest thing to do but it's not that hard either. You just need to rent a puller unless you have one and make sure it's centered then just pull the sucker off (once the crank bolt is out of course). To install the new one you want a longer than stock crank bolt so you can use it to pull the new pulley on with. Don't try to install the pulley using the stock bolt b/c you risk stripping the first couple threads of the crank. Not worth it when you can buy a longer bolt for cheap.
If you have the CORRECT puller, getting the stock unit off is seriously a 5 min job after you break the crank bolt free.
Like others have said, don't try to use a stock length bolt to pull the new balancer on. Get a much longer bolt, or, get some all thread, install it all the way into the crank, and then use some washers and a nut to suck that thing on.
If your having issues, heat the pulley up a bit before you try to start it on the crank. It will expand and go on easier.
