What headers have the best ground clearance??
I am kinda torn between headers at the moment. I would like to have long tube headers in my car for the simple fact that it will yield the most power but I am worried about scraping them all the time. My car seems to sit a little lower than my brother's Camaro, but I myself have done modded the suspension. I am also thinking of getting a custom-made y-pipe to have high-flow cats welded in. I am considering mid-length headers but have heard that they don't clear much more than LT's. Anybody have any ideas?
It's the Y Pipe that's the issue with ground clearance. I dont have LT's on my car, but do have a custom 3" catted Y Pipe and it's hitting the speedbumps. Since you wanna go custom y, just get them to flatten the driver side of the y pipe a bit and make sure they have it straight. Mines a lil bent at a certain part, well looks to be bent downward. which is why i think i have most of my ground clearance issue.
I have the SLP tuned (first design) LT headers, high flow cats and Y-pipe on mine at stock height / factory springs and have no issues but I could see how easily it could become an issue with lowered cars. I do believe the new design has taken care of this as it is a long tube design and not a tuned design. Which means each primary takes the shortest route to the collector and not all primary tubes are the same lenght (which is why the tuned headers look like they wrap around each other to maintain equal lenghts)
Either set of the SLP headers are great quality parts. Also take into consideration that these are stainless steel headers with a ceramic coating and the tuned set comes with the y-pipe. The new set comes with the y-pipe and high flow cats. That is the reason you are paying more.
I wouldn't even try the new SLP's....
I had the old ones. Scraped them fairly often at the stock ride height.
On the ProKit with Kooks, and now with Kooks and Strano springs, I have not hit them once.
