Need help with ls6 intake???
I just bought an ls6 intake off of a guy on here and he told me what to get but i cant remember what it is. I think he said it was a coolant block off line or something to that effect. I was wondering where i could buy it and what the part number is. I went to the chevy dealership today and the guy there didnt know what it was. So if any of you guys know please let me know. Thank you
LS1Tech Premium Sponsor
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
ok so if i grind them off then i dont have to buy those new lines and i could just keep those stock lines running through the valley right? or do i have to cut and crimp the stock ones?
Here's a link that will help you and show you what ribs you have to cut out if you don't want to figure it out on your own.. let us know how it goes... good luck..
https://ls1tech.com/forums/generation-iii-external-engine/618070-finally-did-ls6-intake-swap.html
I took all the ridges off with a sharp chisel and hammer. Was MUCH quicker than using a grinder, at least for me. Just take your time. My intake was brand new, I had to pause for a sec before I started chiseling away.
be very careful with the Oil Sending Unit when you remove & replace it.. Also search on the intake threads and it's recommended if you're doing the install to put some rtv sealant around the KS(s) to avoid them shortening out..
One of mine shorted out the next day since it rained and now my SES light is on.. waiting to get them shipped now and I'm out of pocket another $105
https://ls1tech.com/forums/showthrea...733&highlight=
here is a good pic of it... it's circled in green and KS = knock sensors.
