running on 4 cylinders
Old 09-09-2008, 03:39 PM
carbonfiberbird's Avatar
Default running on 4 cylinders
89 formula 5.0 TPI a4, its running on the driver side 4 cylinders, getting spark and fuel any ideas?
Old 09-09-2008, 03:46 PM
toneloc60's Avatar
Are you sure you're getting fuel in those non-firing four cylinders? IIRC, TPI systems are bank fire.
Old 09-09-2008, 03:52 PM
yeah its getting fuel, do you think it could be a grounding issue? thanks for the help by the way!
Old 09-09-2008, 04:12 PM
whats "IIRC"
Old 09-09-2008, 05:01 PM
anyone?
Old 09-09-2008, 05:16 PM
99345hp's Avatar
I would check for loose grounds and make sure the injectors are getting a signal from the computer.
Old 09-09-2008, 06:50 PM
yeah, thats what I'm thinking. We just replaced the computer recently.
Old 09-09-2008, 07:45 PM
Orange 02 WS6's Avatar
Originally Posted by carbonfiberbird
whats "IIRC"
If I remember correctly
Old 09-09-2008, 09:10 PM
HMERacing's Avatar
Check the injector circuit fuse under the hood, there are two of them, on for each bank.
Mine shorted out behind the pass side head after a trans swap. The wire didnt look bad until you pulled off all of the loom off of the harness and looked real close. I had to pull the intake to get to it.
Old 09-10-2008, 02:13 AM
yeah I'm gonna check a couple suggested things tomarrow at work thanks guys, and when I find it I will post what the problem was.
Old 09-10-2008, 11:16 AM
toneloc60's Avatar
Good luck and let us know what you find. I'm always interested in stuff like this just for the knowledge.
Old 09-10-2008, 11:21 AM
tee-boy's Avatar
Default third gen
You need to post this on thirdgen.org
Old 09-10-2008, 04:57 PM
thats what I did, we finally found it! It was the Injector 2 fuse. Something simple we just over looked but still really happy its done! Thanks for all the help guys
Old 09-10-2008, 07:33 PM
HMERacing's Avatar
Glad to see you found it, hope it doesnt blow again due to a short somewhere though.
