My dyno numbers.....
I have a 2000 trans am ws6 m6 that i had full bolt-ons and a cam put in.
here is the list of parts installed...
Professional products typhoon intake and throttle body
SLP Double roller timing chain
180* thermostat
pacesetter LTs and ORY
Beehive valve springs
Chromeoly pushrods
224/226 581/585 114 lsa
On a mustang dyno i put 361.1 rwhp @ 6600rpm and 325.6 rwtq @ 5200rpm
what do you guys think of these numbers???
thanks
180* thermostat
Chromeoly pushrods
thanks
The torque reading is a little off... usually they are within each other by a lot closer than that...
Mustang dynos usually read lower for both numbers, but the torque value is off...
I think that the reason my torque numbers are so low is because the motor has 125,000 miles... and with the longtubes and my muffler is pretty much empty so it sounds a lot like its straight piped... thats all i could come up with..
even though the peak is kinda low the torque stays over 300rwtq from 3000rpm to 5100rpm so im not going to complain about the peak..
thanks for all the comments guys...
