I Need Instructions On How To Wire My CutOut
i have 2 cutouts just installed on my car and i was lookiing for instructions on were to hook up the main power to. the reason im asking is cause i have to cutouts hooked up to 1 switch meaning there is going to be more amps ran....and dont want to blow **** up so i would like to no which fuse bank should i run in with.
thanks
thanks
im sure a 20 amp relay will be more than enough for both...
if you are going to be getting your power source from the fuse block, never source it from a fuse rated at a higher amperage than your relay...also make sure the fuse is only energized when the key is on the ACC position..
