Is this pcv set correct?
sorry guys i don't know how to upload pictures into a current thread. However is this setup now correct? The top line has the pcv valve in it and going to the valley cover. The bottom line goes straight to the side of the intake manifold.
Also don't some guys disconnect the line going from the throttle body to the valve cover?
You need a filtered fresh air source. I believe that if you run a breather on the valve cover, you can delete the line from the TB (more common in FI applications).
