Piston To Intake Valve Clearance
im running a stock LS1 bottom end (crank/pistons/rods) and:
comp cams - XER287HR-12 -238/240 -605,609 112LSA
trickflow 215 CNC heads
YellaTerra 1.7 adjustable rockers
my problem is with this cam installed 110deg intake center line.....
i only have 55thou piston to intake valve clearance
any suggestions/thoughts on this?....cam phasing?.....
many poeple running big cams run those tolerances. Ask for MS4 clearance around, it is about the same.
besides flycutting, you could also sink your valves a bit.
proper way is to flycut and mill head.
thanks for the replys guys...it seems retarding the cam only compromises the exhaust valve clearance...i have tried 8,6 and 4deg retarded to check the clearances....so far 4 degrees has given me the most for both inlet and exhaust....
will try 2deg tommorow but i may end up having to fly cut as some of you have said already..
thanks,
douglas
thanks,
douglas
