sprocket gring cam plate?
hello everyone! i need awansers and hopefully someone can help me out.
well i just recently installed a cam in my 2000 camaro, and have sine put about 1500 miles on it. well the problem started one day when i decided to go for a little cruz, i pull out my drive way and get about 3 blocks from my house when my car started acting funny. i noticed i had no oil pressure(loss of power, fluttering realy bad, guessing it was the vales filling with air), assuming my oil pump went out. i turn the car off, then start it again but still no pressure. so i towed the car back to my house. today i changing my oil pump i noticed a good bit of metal shavings in the oil as i was draing it.i decided to pull the cam sprocket, then i noticed grinding marking on the back of the sprocket and cam plate! what could have caused this to happen? i was not happy to see this, it made me feel sick to my stomach. im just praying it no my cam bearings. i tried to move the cam to see if it was loose but it would not, although i was able to turn it by hand.
its a trex from thunder racing. i compared stock vs trex, they were the same length. the cam was rubbing a little but nothing that would worry me. the sprocket "grinding" on the cam plate it whats got me.
Lack of lube is what I would say, actually wait that would have nothing to do with oil pressure loss so yeah you lost the pump and it ate the cam plate, that plate is what keeps the cam from moving forward to back, there are no cam bearings that control that, not like the bottom end, the bottom end uses a thrust bearing to keep the crank from moving front to back, that plate is your cam thrust bearing.
I would imagine the snout of the cam is probably galled now too, as long as there is a film of oil in between those pieces that should not have happened unless somehow the fitment of the pieces actually caused a lack of clearence, when you get the new plate slide it over the snout of the crank and bolt on your new cam gear and make sure it all spins freely.
Just in case you dont realize this, a film of oil on metal to metal parts actually keeps the metal from touching, the oil molecules will seperate the pieces from touching unless the clearence is so tight that is squeezes the oil out.
Exact same concept of how a crank can spin in metal bearings without touching.
thanks for the help! i just relized i spelled grinding wrong in the title. so you think they had contact once i lost oil pressure? so should i start reassembly now? the front of the cam is fine, just a little burn mark on it.
thanks ,chad.
thanks ,chad.
well i have a new oil pump, chain, and sprocket. the only reason i think the cam had contact with the plate is because the sprocket was pushing on the plate. on the otherside of the plate where the cam made little contact with the plate there was just a little burn mark, nothing that would make me think that the font of the cam was damaged.
Now if you had oil pump misalignment of some fashion that caused the chain to pull the gear back then I guess that could happen but havent heard of that issue before.
