Splash guard under crank !!
Hi wonder if somebody can tell me how important the splash guard/plate or what the name on it is. I have built a new engine and mount it in the car, and of course I forgot this plate. And what is the name on it?
Any help would be grateful. I’m adding a picture of it, so you all understand what I’m talking about
Reg Chris.
Reg Chris.
Without the windage tray, the crankshaft will suck up the oil in the pan onto itself. The rotational force cause the oil to wrap itself around the crank, causing an increase load on the rotationing assembly. This results in reduced power.
People running larger than the stock 3.668 (whatever it is) stroke have to notch this the clear the connecting rods on BDC due to the longer stroke. Like say a 383s 4.0" stroke. Some poeple just dont run them. It causes you to lose a few hp at top end. The windage tray helps to scrape excess oil off of the journals too from what i understand.
ok ok i dont want to sound like some huge jerk being new here and all but did anyone else catch this U built this engine and dont even know what a windage tray is called? I hate to say it but i dont see this motor lasting long...
Um up until this past week i thought a Chicago valve was the name for the 1/4" quick disconnect fitting used on like impact guns and such. This is coming from a guy who uses tow behind air compressors and jack hammers at work all the time and air tools at home. Not everyone always knows everything even if they do it ever day.
How do you button up a motor and then realize you've left a needed part off. You need a checklist or have your parts layed out in a logical order on the workbench if you aren't the type of person who just automatically remembers everything. I think "windage tray" is somewhat of a misnomer. How about "g force" tray or "scavenge" tray or even "skim" tray. Fuel and Alcohol cars use wet sump with baffles and a pickup tube that swivels back and forth when the oil in the pan is slammed fore and aft. I think if I had gone through all of the steps to do a rebuild and then realized I'd left this part off I wouldn't even be asking this question. I would instead be removing the pan screws.
