View Poll Results: TSP LS6 heads or TSP 5.3 heads
LS6
19
35.85%
5.3
34
64.15%
Voters: 53. You may not vote on this poll
TSP LS6 heads vs TSP 5.3 heads
Finally got the money for a set of heads and was wondering what set would be better for my T/A its got a TR 224/224 112 lsa cam in it, a set of headers/ory and a catback, and that's it as far as power mods
So which one would be better, it's primarily a show/cruise (including the hot rod power tour) car with a once a year trip to the track, other than that it stays in the garage
My primary concerns are do I need to fly cut the pistons with the cam I have, and the increase in compression (91 octane is the best we can get here) and do I have to upgrade my injectors
So all you gurus, what's your opinion
the 5.3s will give you better throttle response, and more bottom end to have fun with..... you wont take advantage of the ls6 heads with a cam that small..
no you will not have to fly cut with either one of those sets of heads..
you will be fine running 91.. you will be ok with those injectors..
Super Hulk Smash
5.3s are 220cc and flow 3-5cfm more from .300" to .600" over the LS6s... the LS6s are 226cc heads.
The 5.3s flow more with a smaller runner, but the LS6s have smaller valves, which make up for the increased runner volume. Overall, they should perform similarly. The difference will be in the compression - the 5.3s provide more compression and more piston-to-valve cleance than the LS6s. Therefore, I voted for the 5.3s.
the reason TSP talks the 5.3s up so much more than the ls6's is because they make a lot more money off of the 5.3 than they do the ls6's..
That is not true. The 5.3 heads, IMO, will make a little more power on compression. Since you only have 91 octane gas, make sure you can get a spot on tune and go with the 5.3L.
LS1Tech Premium Sponsor
Don't worry Mr.2k2 I have dyno graphs comparing them for you. Give us a call & we can get you all kinds of dyno data to help with your decision.
I prefer the Stage 2.5 5.3l heads for the camshaft we're discussing. We can set you up with free milling & thinner gaskets if your looking for the max possible HP gains from this setup.
Jason
Texas Speed
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Here's a dyno sheet comparing a few different head combos we tested last time on the engine dyno
http://www.precisionracecomponents.c...comparison.jpg
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
This is a completely inaccurate statement. We actually make more on LS6 heads than 5.3l heads. This is a good example of someone with no actual knowledge about us making a B.S. statement.
The reason we typically like the Stage 2.5 5.3l head is:
- CHEAPER THAN STAGE 1 LS6 HEADS WHEN YOU GET A SPRING KIT
- ENGINE DYNO TESTING SHOWS BETTER POWER GAINS COMPARED TO 2" VALVE LS6
- CUSTOMER GETS STAINLESS / LARGER VALVES FOR LESS MONEY!!
its a fraction.. nothing you would actually see at the track.. you might pick up a ITTY ITTY BIT on the dyno, but not even enough to see a drop on your 60..
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
i'm confused since you can get the PRC LS6 ported heads with the smaller 59cc combustion chambers and 2.02/1.57" valves to match the 5.3 heads.......aka wouldn't that be the samething but flow a bit more than the 5.3L heads?
Yes the 2.02 1.57 valve combo in the LS6 head is a nice combo. But unfortunately it costs more than the stage 2.5 5.3l heads. For the money the 5.3l makes really, really good power
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Jason, your graph shows PRC 215cc heads and PRC Stage 2.5 5.3L heads. I thought the 5.3L heads were the 215's. Or was that the comparison between the stage 1 5.3's vs. the stage 2.5 5.3's. Just wondering, cuz Im a little confused if that was what the graph was about or if it was about the LS6 heads vs. the 5.3L heads? Thanks in advance!!
