Missing two ARP head stud washers, can I use any ole washer?
Well I have some how lost two washers for my ARP head studs. They are the tapered washers to...Just wondering if I can use a washer from a parts store. As long as I match the same diameter, thickness, ect? Or is there a special reasoning for the tapered washer?
I'm sure if you go by a fastner shop, they would be able to find you something of the same grade or material. The washers used for heads aren't exposed to that insane of a torque load, its just to help disperse the force so you don't gouge your head.
