slp oil pump, which spring??
Hey buddy. I have the pump and used the red spring. It is the hd spring. The pump will come with the weaker blue spring in it. You will need a 8mm allen socket to get out the stop. With my setup I have 40psi at hot idle and 60 at wot.
