l92 heads on a iron 6.0 block
Old 11-09-2008, 07:45 PM
steve40's Avatar
Default l92 heads on a iron 6.0 block
looking at putting the l92 heads on a lq block. right now the block is stock and needs a rebuild, so i'd be getting new pistons. is it better to get a bigger bore since the heads come on motors that already have a larger bore?
Old 11-10-2008, 07:15 PM
Hotrod406's Avatar
They flow more with a larger bore but I'm not sure it's worth it. If your block needs a cleanup, just go .030 and call it good.
Old 11-10-2008, 07:50 PM
NemeSS's Avatar
.030 is good.
go with 2 valve relief pistons for higher compression
mill the heads some too
Old 11-10-2008, 10:00 PM
novaflash2002's Avatar
why go .030 if you dont need to. just bore it fare enuf to clean up the cylender walls. that way you have more re-builds if you want to change combos.
