Valve clearance
Old 12-01-2008, 09:24 AM
Metcalf Racing's Avatar
Default Valve clearance
I was thinking of going to a 2.02 valve my heads are off a 99 corvette and are milled.025 I'm going to run a cam around 595-598 lift around 112- 114 lobe separation probably around low 230's@.050 duration. My short block is a stock 98. Do you guys think I'll have a problem?
Old 12-01-2008, 07:29 PM
anyone???
Old 12-01-2008, 09:09 PM
S10xGN's Avatar
I don't know what the milling does to clearance, but my stock '03 #241 heads have 0.200" clearance with a TSP Torquer V2 with 0.598" lift.
Russ
Old 12-01-2008, 09:35 PM
Randy WS6's Avatar
The common, minimum valve clearance is .100" int. & .080" ext. Try not to go below these clearances. If your close in these clearances you can use head gaskets thickness to raise the heads to give you more piston to valve clearance
Old 12-02-2008, 06:16 AM
Thanks. I was planing on running the 02 camaro gaskets.
Old 12-02-2008, 08:20 AM
PREDATOR-Z's Avatar
Actualy it is the opposite .080 intake and .100 Exhaust
But many poeple run lower than that with bigger cams.
