Ajustable timing sets.
AM I correct to say that if I have a 9 keyway crank double row sprocket, each time I go foward or back one keway, that IT SHOULD NOT change the LSA by 30+ degrees. EX: foward one key changing the LSA from 111.5 to 144.
+4, +3, +2, +1, 0, -1, -2, -3, -4
Here's a description I found on the net:
"CLOYES BILLET TRUE TIMING CHAIN SET -- Features A Heat-Treated Billet Steel Sprocket, 9 Keyway Crank Settings For Easy Adjustability, Timing Chain Style Is Double Roller Chain With 0.25 Rollers, 4 Degrees Maximum Advance/Retard At Camshaft, 8 Degrees Maximum Advance/Retard At Crankshaft, For Factory Roller Cam"
I finally figured it out. It is a rollmaster. What was happeneing is that I was adjusting foward and realigning the same stock timing marks cuz thats the only ones it has. Through out instructions long time ago. But finally got LSA wihting .625 of what I wanted so thats where it should stay. I belive the slack on the gear and chain is what the error is. But I got it. What I adjust it to the keyway I wanted and realigned the nearest tooth clockwise and it worked. Took about 20 times but I got it done. Thanks guys.
