Forged Engine
Old 12-08-2008, 12:14 PM
jeremy02's Avatar
Default Forged Engine
How much to forge my engine and keep stock cubes? Or would I be better off going ahead and upping cubes if I'm going to forge it?
Old 12-08-2008, 12:26 PM
99blancoSS's Avatar
Well if use the stock crank clean up the bore .005 you'll have a 347 for cheap money vs the added cost of a crank at $750 or there abouts for Eagle.
But after you do all that work and spend that money our right back at the same power levels unless your going with a power add. SO.... thats why a lot of people will spend the money on the crank to see some gains.
Unless of course your running nitrous or a turbo or s/c.
th41427's Avatar
Default my cost
You are looking at around a 1000 or more for good pistons and rods. plus you got rings ~250 and bearings about another ~200 then machine work and assembly
Old 12-08-2008, 04:06 PM
jeremy02's Avatar
I'm actually probably going to sell my car, but I was thinking if I keep it I'll HAVE to forge it. I beat the **** out of it.
What about stroker kits?
