Can you replace rod bearings with out doing machine work? Can you just take the old ones out and put the new ones right in and bolt everything back together? Thanks
Like LS1MCSS said, If you have a spun bearing there's no way you can just change bearings with out machine work, But if you just have high mileage and want to freshen up the bearings then you can.
